hot water not getting hot
22 Mar 2006
Coventry
I have a Sloar 80e boiler that was low on pressure and the rads needing bleeding. I have done this and now it is fine-well the heating is. Only now the hot water is not getting hot. The burner fires up on demand for the water only it goes the water is luke warm. The water was getting hot until I bled the rads and got the pressure back up. Can anybody help?
You presumably mean Solar. It sounds like the diverter valve is allowing heated water through to CH flow pipe when in HW mode. You may need a new diverter valve.
Cheers, I shall have to have it looked at. I think it is the diverter valve as I checked everything else
