I'm going to try something today.
A mate of mine has got the same boiler as me and he's happy to 'lend' me the hot water temperature sensor out of his boiler, which is working fine, to test on mine to see if that's causing the problem, so I'll give it go. Nothing to lose really as I don't think that there is anywhere open today where I could pick one up and even getting one tomorrow, the supplier will probably have to order me one in anyway?
Any takers on my other questions above![]()
Well that was a none starter.......Someone has previously had a go at the hot water temperature sensor on my mates boiler and has wrecked the screw heads on both screws which hold the sensor in place.God help him if he ever needs to swap his sensor over but I couldn't get either of the screws to budge.
Just thinking about what the temperature sensor actually does though, if it was faulty, would it not either a) give hot water at its maximum temperature only or b) give no hot water at all.
My water is luke warm but the burners stay constantly fired-up whilst there is demand for hot water, so the sensor is correctly not sending a signal to the burners to switch off as the water is not reaching temperature. Just a thought![]()
Hi Again Mr M,
You are quite correct,the domestic water is not reaching temp,why you
may ask,answer ,as previously suggested plate H. E. FULL OF CRAP,
You need to remove H.E. and clean out , preferably with citric acid ,obtainable from merchants! Good Luck. Keith.
