hot water only gets to 60 degs
31 Aug 2010
London
Hi any help much appreciated
I have a Biasi m90e 24s approx 5 years old with no problems up to now.
CH works fine but DH water only gets to 60 degs on the guage, also when hot water tap is on the water is only warm...? so no baths without boiling many kettles.
when I turn the shower on the boiler does not come on at all(not sure if this helps) water in the bathroom and kitchen is the same approx 60 degs
I have measured water pressure at about 10L PM.
All was working fine until I got back from holiday ????
Thanks in advance
was anything put ino or pulled out off the airing cupboard
could you disturbed the temperature sensor on the tank assuming one is fitted
It doesn't sound right. 60°C is hot and should scald quite quickly. I sounds like the sensor is not sensing the true water temperature. I can only suggest you get a heating engineer in to look at the boiler.
