no this is how it is, i thought this was a bye pass valve, its on a tee piece so the 15 mm pipe does return, the gate valve is in between the return and the pump ?
Sounds to me like you're testing people!hi everone i have a little prob ?
had a new boiler fitted approx 4 months ago a glow worm flexicom hx
it was just a boiler install and i have kept the existing hot water tank etc
now boiler works fine central heating fine
the hot water does not get hot enough hit is about 38 deg
i put the hot water on for approx 2 hours. run some off and its approx 38 deg
i have turned the cylinder thermostat well above this approx 70 deg plus.
doesnt seem to do anything
the boiler setting is at 72 deg
how do i get the hot water a touch hotter ? or tips please thanks
