As tincup and slapper said you most likely have an air lock or sticking ballvalve.
If you still get hot water to the kitchen tap then it's an air lock in the pipe supplying the bathroom.
There is no way a 3 bed terraced house should need a pump.
You could have an air lock.
Where is the cold feed for the HW tank in the attic?
HTH
tilak";p="1487827 said:hello everyone,
I recently bought a 3 bed mid terrace house in south harrow. The house has a Potterton system bolier. The water cyclinder is in the attic.
can you do a picture of this cylinder in the attic and any other tanks etc. up there
Nige F";p="1490427 said:hello everyone,
i will post the picture in few minutes.
Thanks, had a look - obviously not much distance between top of Hot cylinder and bottom of cold cistern,( Could have been a massive attic ) Hot pipe from top of cylinder should come off horizontal, then go to a T with one pipe going up and over top of cold cistern ( vent pipe) then the hot water pipe should go straight down , through into the bathroom and on down to the kitchen. If there are any horizontal parts to the pipe , they could trap air. Also the pipe from the cold cistern to the bottom of the hot cylinder should be bigger diameter than the hot outlet ( previously mentioned). Could be drawing air in the vent pipe when the kitchen hot tap is opened ...this air then lays somewhere in the pipe and the problem "snowballs"into an airlock. Also, as suggested it could be the "Ballvalve" in the Cold cistern , partly blocked with a bit of grit etc- allowing the cistern to drain as you draw hot water... then it refills very slowly over a day or so- and back comes the hot water supply Not that difficult for a plumber to check the ballvalve - and worst case scenario, alter a few pipes.
Start with ballvalve even the pipes shouldn`t be a big job - might not be necessary anyway Good luck.
Had a similar problem at a customers house: It turned out to be an easy solution. I opened the stop cock a bit more.
The tank was emptying faster than it filled therefore there was not a good head of water in the tank???
Hope yours is as easy.
You didn't fancy the job then?BTW get a decent registered plumber not a course cowboy
