You need to do two things:
- provide temperature information to the DCD - this is NOT a thermostat, it's a thermister (or similar) that should give an actual temperature VALUE to the DCD controller, not an on/off signal.
- the safety rules for an unvented cylinder REQUIRE 'direct' control of input heat via a spring-return zone valve so that if the water in the cylinder is overheated for any reason, the thermostat (or in extreme case, the associated cutout) will open and the zone valve will close because of its spring-return.
SO: you MUST keep the zone valve on the flow to the cylinder operational and connected through the thermostat with its cutout;
AND to make the DCD box work properly you need to find away of getting a good 'temperature signal' off the cylinder.
From the DCD website:
I think you need to talk to DCD: wiring the sensor in series with the 'stat doesn't sound right.
If you'd mentioned the Megaflo in the first place, you'd have had the answer in one hit
With Megaflow systems, sealed hot water cylinders and thermal storage systems, the sensor is normally fitted within the covered space provided for a thermostat on the side of the unit. Where a thermostat is already installed, this should be left in place wherever possible and wired in series with the DCD provided sensor. Further information available by email.
