Many thanks Breezer for taking the trouble of drawing the diagram. I managed to get to the tube connection on the drum by opening the front cover and rubber.
I disconnected the tube and blowed into the tube and it is clear no blockage. Although wasn't sure what to look for in the chamber (or whether to remove it) as it made of rubber and attached to the drum.
I then blowed thru the other end of the tube connected to the pressure switch which when I blew in I could hear the ticking noise coming from the pressure switch. This probably suggests the swicth is fine.
I then removed the lower drum filter rubber pipe and there was a lot of rubbish hair pins, coins and broken plastic bits and also water, I cleaned it out.
Refitted everything and tried the spin cycle but still no fast spin. One thing i would like to ask is whether I should fill the drum with water before checking whether the fast spin works or not as after doing these final checks I did not fill it with water.
What I then noticed was that the PCB board fixed to the lower bank of switches (Gentle and Heavy Soil buttons) had come off and has cracked hence not making the necessary connections to the timer switch. This fault be connected with this?
I have to solder the broken tracks, but I am not sure whether these buttons control the final fast spin cycle?
Which now leaves the motor, although the motor is working perfectly.
Running out of options!
