Please help, my washer has stopped mid cycle, the on/off light is flashing rapidly and the wash enhance and reduced creases lights are flashing 1 per second, I've checked my instruction manual and it says if the wash enhance/rinse hold/mini load lights are flashing it means the machine has failed to drain probably because the pump filter is blocked, the door wasn't locked so I checked and the washing while wet wasn't dripping so it obviously did drain and spin but the fabric conditioner was still in the drawer along with a reasonable amount but not all the detergent powder, also I checked the pump filter, a little water came out as expected but certainly not as much as if the machine hadn't drained (I had that problem once before) there were no blockages that I could see or feel, is there anything I've missed?
