yes heater is faulty found at the back under white panel.
That means a water supply fault , check hoses are not kinked , check presure pipe has not come off , check that it fills twice on a 60 wash poss open curcuit valve.
Nice one, I will have a look when I get back home later. Thanks!
If it's the 4th light flashing on the left that means error code fo1. Which means motor triac on Pcb has failed. Thats got nothing to do with the pump. Have you unplugged it for 2 mins to clear the error.
