hello rocks1
Fitted a new heater element today. Water flowed into the machine and it worked ok for about ten minutes. Then water appeared on the floor under the washer. I cancelled the program. I noticed that the water could be heard flowing into the machine all the time. It was obvious that there was too much water getting into the drum and I suppose it overflowed somehow. Could be the pressure switch? Maybe I'm not fitting the pressure chamber /rubber ring gasket properly so the switch doesn't work? I've checked that the pipe is clear. And I've blown gently into the pressure swich and can hear a 'click'.
ps I'm getting pretty good at dismantling the machine and putting it back together again
The pressure chamber just slides over the ring washer and the two screws tightened.......Is that correct?
