hope rocks1 reads this
The machine refuses to fill and after a couple of minutes gives the error low water pressure.
There is no problem with the water supply.
I have checked the 4 solenoid valves for continuity and they all have approximately the same resistance (about 3kohms).
When the machine is switched on, the voltage across the solenoids reads 0, but when a cycle is started, the voltage across all 4 solenoids measures about 70V. If the cycle is paused, the voltage returns to 0V
Any ideas ?
Any ideas ?
