OK so ordered the EMW recon PCB, fitted it but same fault (third light down on, horizontal lights flashing). Looking at the list of fault codes that came with the PCB, this is F18, but same diagnosis as rocks1 pointed to - "fault on control board, check Eeprom".
However, I have the top of the machine off and can hear a humming noise - previously nothing with old board - coming from water inlet area. So I reattached the water feed and machine started to fill with water, i.e. high pressure feed into detergent drawer and drum turning. And it doesn't want to stop - after 45 seconds to a minute, the flashing lights and same fault code returned - so I lost my nerve and powered down from the wall socket. Switched back on a few minutes later, but same thing happened. Water is now about 2 inches above door level and I am loathed to switch it back on as water filling didn't seem to stop like it normally would on a cycle.
Now this particular WM doesn't have a filter in the usual place, just a red blanking cap, so I dont seem to be able to drain the drum. Any suggestions on next steps would be very helpful...
