My WF541 has just developed a fault. The Door Locked light is not coming on therefore the cycle does not start.The door is actually locked but no light on.Fault is intermittent sometimes Door Locked light eventually comes on and cycle will start.
It takes the netruel suppy from the pcb though the motor when whey are worn no fill no spin. You can get the part off eBay or google it. You tube shows how to remove and check them.
I have removed the brushes and they look worn to me,not much travel left.I managed to remove them without removing motor what are my chances of refitting them without removing motor.
Replaced brushes and now machine intermittently has flashing lights.Reduced creases and minimum load flashing. As I say this is only happening intermittently.
