Hotpoint WML520 way too hot
Hi Yardie,
Update. I Fitted the new NTC sensor so thats all done. Selected rinse only and once again, boiling water! Then my girlfriend says "that noise is the boiler upstairs re heating the water" (its her house, I dont live there) so I went to investigate. The installer has connected it to the hot supply not the cold one!! I connected it to the cold and it leaked at the wall so i used a new hose and it leaked again, the Tee junction 15mm connector looks old so it needs a new one I think. Anyway I tested the machine albeit on hot supply again and it was ok so i drove home 25 miles and then she tells me its not working so back i go to discover the bloody hose had kinked when i pushed it back into place so no water flowing in...nightmare!!
Seems you have this under control now.
Probably best to have it connected to the cold feed so fix the leak.
Possibly connected to the hot feed as the heater does not work.
Mmmmmm good point, she is moving in 3 weeks so hopefully the connection to cold will be straightforward. Thanks for your help
Lets us know the outcome after installation at new address.
