House fuse blown
It was a 32A rewirable fuse. The incoming connection block (on the hob) was badly burnt and causing a dead short taking out both fuses.
I didn't think HRC fuses were "slow blow". I thought that they were designed to blow immediately given a "dead short" condition, hence both blowing.
Any ideas on what it should cost to get the required Cert of completion?
What would the "qualified person" have to do, test the integrity of the cabling to the fuseboard presumably?
Thanks for any helpful responses. (and pictures trojan)
Why can't you just forget about this? You've done the repair and all is now well, apparently...
If you're really that worried about it, then get a trusted, experienced local electrician (not a Part-P know-all) to check why the 60A HRC fuse blew as well as the 30A ("32A" sic) rewireable fuse.
Don't bother with the supplier, he isn't Father Christmas, he's only interested in two things: Ignoring you or dipping into your wallet....
Lucia.
Lot of fuss TBH - Turn off the computer and watch Children in need.......
I want it resealed because otherwise there could be accusations of "bypassing the meter" - Isn't this the reason for the seal in the first place?
If you have only removed the seal on a main fuse, you couldn't possibly be accused of bypassing the meter.
Removing the seal on the cutout is an everyday procedure for electricians. The supplier only becomes anxious when his meter seal has been tampered with.
So, stop worrying - be happy......
Lucia.
The reason for the seal on the "cutout" is to stop un-trained persons from playing with the equipment and carrying out repairs for whitch they are not compertent or insured to do.
