If first fixing a house in copper but having to use a tiny bit of plastic as the joiner has already done his first fix and cant get in to notch the joist bar the main run. Will this give problems as I would be pressure testing the copper at 1.5 working pressure. Not the 18 bar polyplumb tell you to first fix at. Will be like 4 to 6 plastic fittings on the heating pipework so barrier pipe.
