My partner has an old farm house which is a listed building. The wiring was redone about 25 years ago and the consumer unit has a single RCD which supplies all the MCB's.
We have had issues with the RCD tripping out on occasion. There are a few oil heaters around which means it is difficult to test every item in turn as they may only have a fault when hot/cold or the thermostat switching in/out. The type of construction of the hose also means damp behind sockets is another thing to consider.
We tried switching off the power to the outside lights when we were last having problems however the MCB's are only single pole so if there is a neutral to earth fault outside power can still go along the neutral outside to earth and trip the MCB that way.
We got an electrician in last weekend to disconnect the two outside circuits entirely. That seemed to fix it as we turned everything on and no issue. However we later went upstairs and turned on the 20W table light and it tripped. Eventually we found we think it is one of the oil heaters as it hasn't tripped the last few days since we stopped using it.
Anyway thats the background and it is becoming a real pain as we have had this issue twice this year. So one plan is to upgrade the consumer unit.
Can someone with knowledge of the latest wiring regulations tell me if this setup is permitted and if not what additions would be required.
Enclosure only consumer unit.
Isolator switch.
Individual DP RCBO's for each circuit.
That way if there is a fault only that circuit is tripped and it completely isolates the circuit as it is double pole.
Isolator switch.
