Yes. There are some other options (SWA, pyro etc.), but these are generally far more expensive than using an RCD. Many circuits will require an RCD anyway.Am I right in saying that all burried cables that are less than 50mm must either be in protective trunking or protected by a 30ma RCD?
'Protective trunking' would mean steel conduit, NOT capping.
More than 50mm deep is not usually an option either, as this will cause structural problems with the wall.
Safe zones here:Also the diagram for areas to run cables seems to be quite restrictive I think im interpreting it wrong.
//www.diynot.com/wiki/electrics:installation_techniques:walls
Basically, they are:
vertically and horizontally in line with a socket/switch
vertically within 150mm of a corner
horizontally within 150mm of a ceiling.
Perhaps, although this all depends on the size of cable and what it is being used for.If im attaching cabling to a ceiling joist which will then be covered with insulation am I best running this inside trunking due to the amperage drop from 20 down to 13?
