Hi
I am wondering if I can get some advice. I am in the process of renovating my 3 story terraced house, but am getting conflicting opinions from the 3 plumbers that I have had round to quote for the renovations. The current situation is fairly straight forward. I have a
- W/C with shower on the ground and top floor
- A kitchen with a dishwasher on the 1st Floor
- A utility room with a washing machine on the ground floor
- No option for further extension, roof conversion, so it is highly unlikely that the water demands will change.
The mains connection is a 15mm pipe and the flow rates are:
- Above 22 litres / minute from the ground floor cold water
- 10 litres / minute from the ground floor hot water*
- 19 litres /minute from the top floor cold water
- 10 litres /minute from the upstairs hot water*
*The current combi boiler is undersized for the house as it is a Worcester Bosch 25SI, and the flow rate has been restricted down to 10 litres a minute to ensure a consistent temperature. (Boiler installed by previous owner)
The current boiler meets my needs whilst it is just my wife and I living at the house, but when our family grows we are planning to upgrade the boiler to a larger boiler probably a 42. We are considering whether or not If the flow rate is too low to allow the use of showers at the same time, we may then also increase the size of the mains to the house to 32mm (I have already had a quote for this and the cost would be reasonable as the Mains is directly outside my property).
I am getting two conflicting views regarding the existing pipework.
The two views are as follows:
1. Replace the old 15mm pipes throughout the house with 22mm. Leave the old 15mm feeding the kitchen until it is renovated when I could then disconnect it. There is easy access to run 22mm upstairs so long as plastic is used.
2. Keep the existing 15mm cold water pipes. Run a 22mm hot water pipe from the combi to the downstairs bathroom and connect it to the old 15 mm hot water pipe that feeds the kitchen and top floor bathroom. Then if I do end up upgrading the mains supply, connect 3 spurs to the 32mm pipe. 1 to the boiler; 1 to the downstairs bathroom/utility room; and the last to the upstairs kitchen and bathroom. In that way the volume from the 32 mm pipe will be evenly shared out ensuring that all of the 15mm pipes have minimal drop-off in flow if other taps are used.
My questions are as follows:
1. With the existing volumes, do you think a new mains connection will be required?. With above 22 litres a minute from the 15mm mains it seems like I could easily run two showers at 11 litres per minute, which should be a perfectly good shower? (32mm is excessive as a replacement, but the water board surveyor suggested to go for 32mm as the cost difference is negligible.) My concern is that the street is just starting to see the last generation move out and a new generation move in. As a result I expect more people moving from tanks to direct water feeds and combi boilers, so the pressure may be impacted.
2. Should I get 22 mm pipes run throughout the house? Or do you think that the 2nd option should suffice?
3. Overall what would you do to ensure the long term success of the installation? Are there other things I should consider?
I want to get this right first time, as changing it after I have renovated the bathrooms is not an option. I also need to work out fairly quickly if I am going to put in a new mains connection, as I will be replacing the outside wall of my downstairs bathroom as part of the refurbishment, so it would make sense to dig a trench and get a Thames Water authorised plumber to lay the pipe and get Thames Water to make the connection whilst the front of the house is already open.
Thanks in advance for your help.
