- Joined
- 27 Jan 2008
- Messages
- 25,007
- Reaction score
- 2,895
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Back in 1980's I worked in Algeria and I found sticking an earth rod in the ground in HassiR'mel in the desert just didn't work. Hence why I said UK damp conditions. People I worked with said they had same problems in other countries and really it was down to a risk assessment rather than simply following regulations.
I would not want to install a final ring circuit as far too easy for sockets to be changed to German rubbish and so I would say no way around having loads of radials.
Because of the number of circuits I would consider either a double or two consumer units one for each floor. However first one has to know the supply is it single, split or three phase as this would clearly impact on the design.
Single or split double unit would work but three phase would need more thought. AC units are the real worry as one can real have some large loads and when working in Hong Kong one could see how the electric bill soared in the summer.
Start loads with three phase are very different to single phase and if three phase is an option running AC units from 3 phase supply would seem the way to go.
However the inverter manufacture has jumped leaps and bounds and I left warmer climate too long ago to know what is now on the market and as a result my ideas of how to handle the AC load may be very dated.
The expat electrician is not some expert although many think he is and finding some one who has expat and UK knowledge and has the skills required will be hard.
When I think back to 1980 I was one of those chancers I was lucky nothing went wrong. In the 1990's in the Falklands I was far more skilled and by time I went to Hong Kong I was quite skilled but still I found local conditions resulted in having to deviate from BS7671. It was the first time I had worked on a IT system and believe me that's nasty I carried a neon screwdriver with me and tested every bit of metal before touching.
As well as not knowing if single, split or three phase we have no idea of earthing system and really we need this basic information before we can give any advice.
