- Joined
- 24 Nov 2004
- Messages
- 431
- Reaction score
- 5
- Country
IF
I have a house and a workshed/garage which are currently wired as follows:
incoming TNS header supplies two old "MEM" isolators (steel boxes with wire fuses and main switchgear).
One of these boxes controls the underground supply to the shed (small fusebox, 2xPIR and a socket).
The other box controls the supply to the domestic fusebox in the dwellinghouse, which distributes to the services.
Then,
Would I be well-advised to stick to this general arrangement for renovation (obviously installing RCD protection for the garage)?
or,
should I route the header straight into a split-load CU and take the garage supply from the RCD side?
or is it six and half-a-dozen?
also, what's the proper name for these steel boxes with a number of BS88 fuses and a switch? from memory, the switch is SPST - that's to say, the neutral is not switched in these boxes.
Then,
or,
