You need an Insulation resistance test done on the cable to prove it's servicability.
Which suggests that the cable has had serious problems in the past and needs to be replaced.The armourcore run also has 2 underground joints (remade with proper resin connectors after a previous trip problem).
Nonsense.repair work must be completed to the standard in force at the time of origional instalation
For there to be any point in doing that there would have to be a fault in the cable which could be identified and resolved without digging it up to repair or replace it.In that case....
So do I.I think best bet is to have a new length of cable run out to existing shed?
When the supply cable is fully disconnected at the shed fusebox the tripping at the house main fusebbox stops.
Then the fault is 'at the shed fusebox'.
So the fault must be in the buried cable?
thanks
No the fault is NOT in the buried cable, its 'at the shed fusebox'.
Sorry, I repeated the mistake.
When the cable is fully disconnected at the shed fusebox the tripping does NOT stop.
Thanks again.
Thanks again.
I can't think of what sort of fault that could be.
Can you?
