householder wiring a circuit
17 Feb 2016
Lancing
If a house holder wires up a circuit ie;- shed and runs armoured cable from shed to house then called a qualfied electrician to wire in armoured cable to consmer unit in shed and consumer unit in house and the test and issue a certificate would this be permissable.
If the route and method the cable was installed was visible for inspection, compliant and the design current and voltage drop was acceptable.
Yes
But it would be very wise to get an electrician on board prior to you starting the work.
PS. What about the circuits that are to be supplied from the distribution board in the shed?
Thanks Prentice boy,
forgot to mention would 4mm hi-tuf cable be ok to run to the shed to power 4 sockets (ring circuit) and two lights from a garage consumer unit.
Sorry I meant hi-tuf to run from house to consumer unit in shed and 2.5 and 1.5 twin & earth to power 4 sockets and two lights in the shed
Would depend on the method of installation and voltage drop!
You need to get an onsite visit and advice from the electrician that is going to complete the terminations and testing.
For a start the lights only need 1.0 mm twin and earth.
You probably don't need a consumer unit in the shed. Just run the lights via a switch fused connection unit.
Thanks for your reply. I was going to put a consumer unit in the shed just to be on the safe side as i will be putting in 4 switched sockets possibly more
including a pir light on a switched fuse unit.
The cable that will run to the shed. At the house end, where and how will that attach to the electric supply?
through the wall into the Consumer unit in house into a spare mcb i presume.
