joydivision wrote:
I will just buy the 17th edition
And the OSG, the EGTTBR, a good guide to the Wiring Regulations, and Guidance notes 1, 3, 7 & 8. See this:
//www.diynot.com/forums/viewtopic.php?p=75416#75416
Well book 3 at least but I can’t see even an allied trade being able to understand BS7671:2008 it would be like asking most electricians what is dotted decimal may be easy with someone to explain but hard to pick-up without.
Quote:
and just make sure I only do work permitted under part P
There is nothing not permitted under Part P...
I concur DIY’er is allowed to do the lot it is easy jobs which get daft replace a non run on fan for run on fan and council want £70 which is more than whole job costs?
Quote:
The outdoor lights don't need to be bright so I will just use solar ones.
By "don't need to be bright" do you mean "don't actually need to illuminate anything, just give off a gentle decorative glow"?
In the main I concur but using solar cells can also require part p if not one piece unit again daft prices from council.
Quote:
I have a multi meter for checking resistance, and I have a very basic socket tester which is pretty useless as they don't test the resistance of connections etc.
Start looking on eBay for insulation resistance, continuity, loop & RCD testers....
To hire all singing dancing £75 per week. Single meter about £35 per week. Since I would think you will soon get fed up I would hire for first job and see how you get on.
Quote:
Changing light fittings/sockets/switches in none special zones is as much as I would ever need to do anyway.
That's a bit different from "What is the easiest way of becoming a P part competent person?"....
That’s now all I do and I am qualified as costs too much to do small jobs under Part P full re-wire OK but add a socket in kitchen no way.
Quote:
It seems like being a domestic sparkie must be a dying trade if with all the courses you need to take, although most trades/careers take several years to learn.
You've always needed (as in "should take") all those courses.
Again I concur but for many years the domestic trade did many things that in industry would have been an no no and rules have not changed much only the enforcement and still you get people asking can’t I do xxxx without fitting an RCD. In industry it was why did that fail. On same RCD as what! Then fit RCBO’s now. i.e. down time costs money and forget rules and regulations industrial injuries are also expensive so it was done correct and any chance’ers were quickly shown the door well at least in the main as I carried on working and now it’s the same for domestic market.
__________________
That’s my opinions
Eric
P.S. like yourself I did get a degree so we know what that means!!!
