I am sure this question has been asked a thousand times but when I search for radiator outputs all I get are calculators that work out what size radiators I need for a specific room volume.
We have 5 large (2000m x 600 approx) very old steel double panel radiators without convection fins in our community building. These are more than adequate to raise the temperature to a set value in a given time. However they are very heavy, dropped on the supporting brackets and causing air leaks in the pressurised system. In addition they project a long way into the room (140mm) is which causes an obstruction for activities like badminton etc.
We are currently getting quotes for boiler replacement/upgrades and at the same time replacing these rads with modern slimmer convector rads. All three companies quote different rads and it's difficult to guess if they are similar of oversized for the task.
One company has quoted for 6 Henrad Compact rads which for a single panel convector only projects 83mm which is perfect. I know the output from the spec sheet for the Henrads but I want to calculate the output from the existing rads to compare total overall output. Is there an easy way to do this? I have no idea of the make and they were probably installed in the 1950/60's so cant go to the manufacturer to get data.
Any help would be appreciated
