you're both correct, i shouldn't commit without actually inspecting.
however my reason for being so sure is ive had (what appears to be anyway) the exact same cutout fit for that upstairs flat that i mentioned in another post. i watched siemens install the meter. if the fuse is removed, a screw can be unscrewed that then allows that lid on the neutral section to slide off. that hides a very large neutral+earth brass block. both the neutral and earth cable in this picture are linked to the same connector block, therefore it must be PME. (assuming this cutout is the same as what i saw, and im very sure it is)
