How can i wire PIR to light?
Is not the black linking the two sides of the unit the factory fitted link described in the instructions?
Yes, but we're not talking about that - we're talking about the black in the cable which "comes from the ceiling pull switch" - which may or may not be a neutral feed (I still personally doubt it).
But we do need further information in order to help the OP.
Definitely.
Kind Regards, John
the live wire is coming down from the ceiling where a standard pull cord light switch was.?
I read that as the OP has replaced the standard pull cord switch with the PIR so when the PIR is in place there is no pull cord switch.
So did I - but one wouldn't normally expect a 'standard pull cord light switch' to have a neutral, would one?
There probably are some 'in-line' PIRs which (like most dimmers) do not require a neutral. However, the OP's does not seem to be like that. Furthermore, if the 'cable to the light' means what it says, then that clearly would require a neutral.
We really are wallowing around in speculation unless/until we get some more information from the OP.
Kind Regards, John
but one wouldn't normally expect a 'standard pull cord light switch' to have a neutral, would one ?
Many lamps are connected to a supply by a length of twin and earth to the consumer unit and some where along that cable the Live is interrupted by a single pole switch with the Neutral passing through un-touched.
In a 'standard' domestic lighting circuit? However, I agree that what you suggest is not impossible - but, as I keep saying, all this wild speculation without proper information is not going to help the OP.
Kind Regards, John
