I've bought a new build property & I am looking to floor out the loft for storage only - boxes of clothes, etc.
The loft is insulated with one roll of insulation between joists, and another laid over the top at 90 degrees to the first. The joists are 70mm high by 35 mm wide at 600mm centres.
What I'm not sure of is if I have to lay down more joists at right angles to the existing and lay the top insulation layer between them, then floor over that ? The new joists would have to be 200 x 47mm c16 construction timber to achieve the required 270mm insulation thickness but would that be too heavy? Is it true this can be reduced to 100mm when boarding and is that with compressing it the insulation? Is that too heavy? It's about 10 sqm in total. Sounds like a lot of work... ?
