How do I connect a PIR to a light ?
Would the terminal block in the PIR simply contain supply and load terminals?
Kind of.
The PIR requires a permanent live and neutral feed to operate and has a switched output.
The first two connect to the live supply, then the load (light fitting) connects to the neutral terminal (with the incoming feed) and the switched output sometimes marked "SL".
