How do i connect LV Transformer to Lamp Connector?
31 Jul 2004
I've got a prewired low voltage transformer and one of these http://www.toolstation.com/shop/Lig...g/Spare+LV+Lampholder+MR16/d220/sd3066/p99286
I thought i could pull the lamp connector cables out of the lamp connector and push the wires from the transformer into it but their completely fixed and cant be removed. So opened the transformer and the prewired cables are soldered to the board. So the only other way of connecting them is through the use of a connector block which doesnt seem the right way to do it. Just wondering if you can get the lamp connectors on their own with pushfit connectors? Or any advice on the correct way to do it
Usually the connecter block is fitted on as part of the down lights.
If not I use Red thru crimps.
