The actual boiler cycling happens when the flow temperature is set quite low as I discovered recently and it also happens when running just the attic zone, which has a 1.7kw radiator and 12kw of heat being in.
Yes, I personally found our installers pretty old school, if only I had known more at the time.
They are probably installing so many systems with old size rads that run at 82/71 and telling customers not to turn the boiler down, so most of their customers will not benefit from full condensing efficiency.
Or ch installers who do not know how to size the rad properly
