A
ahuman
I could tell you but then I'd have to ....
Busy at the mo, I'll tell you tonight, but an eaelier poster had it about right
I'm waiting too. wondering if they need to work on my "live" meter shift?
Shroud all exposed earthed metal work with non insulating material
Quite so - which is, I presume, why stillp was implying that the shroud covering earthed metal should probably be "insulating", rather than "non-insulating"If working live you DO NOT want any exposed earthed bits near you when working on live cores.
A CU somewhere, I expect.Any idea what caused the fire?
If there is a fault on cable buried in ground, how do you locate the fault in order to repair it, replace joint etc?
That presumably requires an awful lot of cabinets or an awful lot of cable (or somewhere in between!)!Why can't they terminate main cable into Feeder Cabinets along the street, as they do in China, and run service cables to house off that? (with correct fusing at the Feeder Cabinet.) No more live jointing required.
