How does one get into car repair for a hobby?
Mechanical or body repairs? What sort of repairs are you interested in - engine, gearbox, brakes, suspension?
Without any experience and a decent tool kit, you might struggle. Many jobs on cars require specialist tools or diagnostic tools - expensive for one-off use! In any case, once you have, for example, replaced some brake pads, that’s it until they need replacing again unless you go over the same things yourself.
I'd suggest looking at going on some car maintenance classes in evening classes if they do any such things near you. Although you said you don’t want to, you can’t beat the satisfaction of doing something on your own cars. Start with simple stuff like routine servicing, Oil and filter changes, air filters, checking brakes and steering joints, topping up fluid levels etc.
I am more than happy to pay for servicing on my car to keep its service schedule upto date. Doing it myself would void that.
Mechanical not body, thanks I will look into local courses but I hope it's not full of youngsters.
How true, and same here.
1 job I do not miss is re lining brake shoes. Do commercial guys still do them though ?
Yep. On commercials we used to chisel the rivets off, remove the linings, fit new linings and peen the new rivets over with a hammer. Used to overhaul king pins too - reaming the new bushes out and shimming the thrust washers. Overhaul shackle pins on Bedford trucks, replace propshaft U/J's and centre cushions, on cylinder heads we'd replace valve guides, cut new valve seats and even draw file it.
Last relining I did was late 80's on commercials.
Wasn't sure they still do it. Dirty job
Not been a truck driver since the late 'eighties, but even back then 'elf 'n safety was a concern due to the asbestos.
I believe the industry has long since gone over to non-asbestos linings .. now the drums wear out quicker.
It's a "long apprenticeship" if you're starting from scratch! I too, would suggest a modest classic car - Morris Minor, Mini, Triumph Herald, Midget, etc, and start from there. If it's a second car, you won't be under pressure to have it ready for any particular deadline. Maybe joint the relevant enthusiast's club, and get to know people. Evening classes are also a good idea. Do you have space to work on one in the dry?
I'm probably missing the key component here, but.... why would servicing yourself void the schedule? Just write it in the book yourself and reset the onboard computer using the non "plug it in" method all cars have (which will vary depending on make/model).
When I first saw the thread title "How does one get into car repair for a hobby" my mind instantly replied 'be too poor to afford a garage to fix it', sure got me fast tracked into it:LOL: Still as yet to afford a set of tools, managed servicing, repairs and even an engine swap using hand-me-downs!
As others have mentioned, a 2nd fixer upper car is probably your best bet, a base model basic hatch from the early 00s perhaps. Something like an old corolla, or even a suzuki swift up till about 2015 is very simple mechanically with easy enough access. Any older and you're going to be looking at learning bodywork pretty fast. Other plus to an older car would be the likelyhood of being able to get classic car insurance, where you're probably looking at £50-80 a year rather than £4-500.
A swift is actually a very good type of car to start on, a few around, generally rust isn't a real issue on them.
Servicing a vehicle yourself (even by a qualified mechanic) could upset the warranty. Needs to be completed to manufacturer approved standard, by a vat registered garage, using Original equipment (quality) parts and oil.
If it's not under warranty then none of that applies
More likely £100 - 150 for classic cover these days, but your point is taken.
That bit isn’t true. No need for a vat registered garage and no need for OE parts. They do say you must use equivalent quality to the original parts and in the event of a claim, it is down to the manufacturer to prove they weren’t of equivalent quality. I've always serviced our new cars from day one after getting confirmation from the manufacturer (Ford and VW).
All secondhand warrant policies insist on a vat registered garage so that 'servicing' can’t be backdated in the event of a claim.
I did say oe (quality) parts, meaning they must be of the same standard. Excludes lots of cheap pattern parts.
I'm not sure where you find infornation that a non vat registered garage can do the work. Fairly sure that still applies.
Tell me about it!
I bought a modern classic (1998) from a dealer over 4 years ago & the purchase came with a 'free' 2 year warranty.
Studying the small print revealed that not only was there a plethora of items that were not covered the conditions were exactly as you have stated, plus it needed to be carried out every 6k miles/6 months .. which ever was the sooner. This would equate to 2 services a year for a car covering around 5k miles.
The document was re-cycled, that's all it was worth.
Plus finance , lease and other agreements may have clauses about servicing too.
Don't just assume any old service will keep any warranty intact
The owner could do it themselves as long as it is to the manufacturer standard. I enquired to both manufacturers and had written confirmation stating that as long as it was done to manufacturers standards and using parts of equal or greater quality, there would be no warranty problems.
