We are doing a loft conversion and need to move the existing cold water tank which is on a raised platform in roof (about 70cm high). To keep the platform and move it closer to the eaves - we can only fit a 25 gallon tank in. OR we can have a 50 gallon but it will have to be at loft floor level.
We are putting in an Aqualisa Quartz digital shower ( which includes a pump). So the only effect of a lower cold water tank, I have been informed, is on hot water pressure coming out of bathroom taps.
All cold water taps in house including bathroom are direct fed from mains and downstairs we have a venturi shower (which is great). In loft planning on an electric shower and electric hot water hand wash tap ( cold water mains fed).
So no great need to store lots of cold water. The question is - if the cold water tank is 70cm lower will this noticeably effect the hot water pressure coming out of the sink tap and bath tap ? ( the hot water cyclinder is in airing cupboard in bathroom)
And if so why ? I don't get it
Will post results whichever way we go Thank you for your advice
