Back in the day when (some) laser printers had plug-in font cartridges, some enterprising person produced one containing a 2-point font so that people could print large spreadsheets.
It does indeed. For a project I was involved with fairly recently, in order to be able to see an 'overview' of the data, we had spreadsheets printed out on A1 paper, using as small a font as we dared (IIRC 5pt or 6pt).A3 says it all.
All decent slide rules had log log scales (usually in the middle of the sliding bit, IIRC) - one needed them for calculating 'powers'.Think I still have a slide rule some where with a log log scale. Or may be J is imaging it?
My A-Level and undergraduate days pre-dated electronic calculators (we had some use of 'mechanical' calculating machines at uni) - so we were totally dependent upon slide rules and log tables. Exam questions usually indicated when (not very often) 'answers to 4 significant figures' were required, in which case one used tables - otherwise everything was done with slide rules.I had to learn how to use one in college but by that time I was very quick using log tables so only used it to pass test never really used it to work out sums.
The ability to rapidly estimate the approximate answer (by mental arithmetic and/or scribbles on paper) is as important today (because it's so easy to mis-key into a calculator) as it was back then (because of the decimal point issue with slide rules). I found it reassuring to see that such 'approximate estimation' was part of the GCSE maths syllabus when my daughters were doing them (in the mid-late 90s).For one thing I kept getting decimal point in the wrong place. If I knew approx what the answer was OK.
As I said before, the main purpose of a log log scale on a slide rule is to calculate powers (e.g. 23 to the power 3.7), not to determine 'log log' values.Clearly later used calculus where we found log of log but not with slide rule.
Slide rules generally work by having log scales. Example : Multiply A * B.Think I still have a slide rule some where with a log log scale.
Roughly right - except for 0/zero, read '1' (you don't get a zero on a log scale)....Example : Multiply A * B.
The answer can be done by additional as Alog (log A + log B). So starting from 0 on the fixed scale, move along by a distance of A on the scale. Align the zero mark of the moving section to here. Now move along to value B on the moving section - and read across back to the fixed section.
Doh, you can tell it's a long time since I've used one can't you Must try one out on the youngsters at work one dayRoughly right - except for 0/zero, read '1' (you don't get a zero on a log scale).
I've got one of those - if you think about it it's a slide rule for vectors.For even more fun, try a "whizz wheel" as used in aviation - or at least, used only until you've proved you can use one and then you never touch it again !
Useful to have and know how to use one if for any reason all your electronic aids stop working.Actually they are quite useful - unless you have an electronic calculator handy which is a lot quicker and easier.
Indeed - along with a sextant!Useful to have and know how to use one if for any reason all your electronic aids stop working.
Maybe you are mixing with the wrong "electricians"You guys seem more knowledgeable than US electricians.
