I have just bought a house that has a botched heating system. The Glow Worm 30CXi combi is downstairs running four 730mm high X 800mm wide single rads, on a 15mm flow and return heating circuit.
I estimate the total BTUs of these four rads at 13,000 (3.8 KW). Are the 15mm F and R pipes sufficient for the load?
If I wanted to add four extra rads upstairs, can I tee off the F and R pipes on the short run of 22mm F and R underneath the boiler? The new rads for upstairs will be approx 50 percent more output than the existing ones. Should I run a new 22mm F and R circuit for these, or is 15mm OK?
