What do you guys think about the life span of Halogen lamps, I've seen cheap ones pop after an hour.
As BR said, buying 240V rated good brand lamps helps. The quality brand issue is fairly obvious, but do also watch for 240V and not 230V lamps. Without wishing to go through all the explanatory rigmarole again, our supply is still 240V in practice, and that 4% over-voltage can halve the life of a lamp.salem2000 said:What do you guys think about the life span of Halogen lamps, I've seen cheap ones pop after an hour.
Interesting remarks made but i would like to see where the original information came from before making comment on it, it states that the information came from the Philips lighting forum this may have been a posting from someone rather than an official reply?ban-all-sheds said:Any thoughts on the information provided here which seems to suggest that permanently running halogens at less than full voltage will shorten their life. Or does that only apply to ELV ones?
Nothing wrong with getting a larger capacity than needed dimmer it allows for expansion in the future.jdldiy wrote:
P S I run mine off a 2 way switch circuit, using about 3 junction boxes to make the wiring all neat and tidy. Be careful to buy dimmers with the right capacity, I bought mine from the same shop as the lights and they had to special order it. They admitted that they had been advising people wrongly until recently - for 5 x 50W lights I needed a 600W dimmer from memory. I didn't check the maths as such (knowing that if wrong we were being over safe), but worth looking into.
JD
kendor said:Is that the mains version? great bargain by the sounds of it if they are.
