I realise the answer to my question has many variables but please bear with me.
Okay so i'm looking to take out the internal walls of my horrible extension and I know the roof will need Props to support it once the walls come down.
Basic dimensions are that the space is a 6.6m wide and 5.5m deep. but an L shape
The roof is a felt flat rood from the early 90's with fibreglass insulation between the joists.
The joists run across the back of the house across the 6.5m span with an internal wall at aprox 3.3m in the centre and around 3.5m long. This in one of the walls coming down.
There is then a random corridor approx 1m in from the edge running front to back along the 5.5m depth. The ~3.5m joists run across this wall seemingly not being supported by it as the ends are on the outside wall. This corridor wall is also coming down.
The wall that has the 2 ends of the 3.5m joists meeting in the middle is about 3.5m long. Our plan was to prop either side of the wall with 3 or 4 props with 2 scaffold boards running the length of it. so 6/8 props total
Then the wall thats seemingly not needed we were going to prop another 4 over the full 5.5m length again with boards to spread any load that a be there.
How does that sound? Assuming you've managed to follow my ramblings that is?
I appreciate that its not going to be a simple answer but I was hoping that fact all i'm propping up is half the flat roof with nothing above it and not an actual upstairs it might be the kind of question that is fairly easy to answer
