I would consider going up a size.
But if you are warm, and everything works don't panic.
modern pipe lagging is a stiff foam plastic tube, which can be pushed over pipe from the end, or opened up with a pre-made slit to push on from the side (there is a black rubbery version, Armaflex, for wet or underground conditions). The Regs, "Byelaws" grade is as thick as your arm, and the wall thickness is about 20mm (observe this picture, where the hole in the middle is for 22mm pipe).
http://www.wickes.co.uk/Wickes-Pipe-Insulation-Byelaw-22-x-1000mm/p/210013
There are some cheaper own-brands like this. I believe the plastic foam is polythene, it is not soft like a foam mattress and does not squash easily. You can cut or trim it with a serrated knife.
If a 428 is being used then the primaries need to be bigger than 22mm and also an effective bypass needs to be thought about....
Is hot water drawn equally from both cylinders when a tap is turned on? If so, they will cool down at the same rate and both need reheating at the same time. Or do you have separate timers for each cylinder so this cannot happen?Both cylinders are actually heated at the same time - they are connected together to make a total of 290l hot water, they don't supply a different zone, but they each have their own motorised valve.
All depends on why it has gone into anti-cycling modeMy boiler does enter anti-cycling mode when heating the hot water,
Yes. But at that time of night, and even in the afternoon, the boiler only comes on occasionally for the central heating, so most of the boiler's output is directed to the cylinder.I take it your heating is still on when you heat up the water at 9pm to 12:30am?
D_Hailsham";p="3293280 said:Is hot water drawn equally from both cylinders when a tap is turned on? If so, they will cool down at the same rate and both need reheating at the same time. Or do you have separate timers for each cylinder so this cannot happen?Both cylinders are actually heated at the same time - they are connected together to make a total of 290l hot water, they don't supply a different zone, but they each have their own motorised valve.
No separate timers for each cylinder. They draw equally, which is fine by me.
I asked the Valiant engineer why it happens and he said "they do this" - should it definitely not be anti-cycling for any reason?
If your happy, that's all that matters.No separate timers for each cylinder. They draw equally, which is fine by me.
