I hope you guys can give me some advice.
I have an attached garage with three double sockets. These are powered from a garage CU on a Radial circuit. There is no built in RCD in the CU.
As I use the garage for plugging in lawnmowers, drills, sanders and other bits I thought it best to fit RCD sockets. I was just reading the instructions that came with them and it states.
"If a second RCD is fitted in the same circuit it may not be possible to predict which will trip in the event of a fault."
Is this still safe? I assume it means that if the last socket in the line is being used and a fault occurs then any one of the three socket might trip but the power will still be cut to where the problem is. Is this correct or should I fit a RCD spur between the CU and the first socket instead?
Many thanks
Many thanks
