Hi all
The other day I noticed a leak on the elbow where the condensate pipe exits the boiler- it was about one drip per second. I put some MS polymer around the join and the leak stopped.
The next morning I ran a bath. The water was cold.
I checked the boiler, the fault code said there was a problem with the condensate. I peeled the MS polymer away and allowed the water to drip out. I reset the boiler and checked the nearest tap. The boiler fired up. I went up stairs to run the bath again. Again it was cold.
I am guessing that the condensate pipe was fully blocked, hence the drip at the elbow.
A plumber has since dealt with it and all is good, but I'd like to know roughly how much a condensate running a bath would create at this time of the year (with the heating off). I guess it varies from boiler to boiler our's is a Worchester Bosch, approx 15 years old in a two bedroom house.
Thanks in advance
Thanks in advance
