How much for a block paving drive ?
3 Mar 2005
Surrey
I am planning to have the drive block paved - about 90 sqM.
Currently it is cracked concrete in front of the garage, so it will involve digging up the concrete and some lawn area. No drain covers or any other obstacles. What would I expect to pay (Woking area) ?
How long is a piece of string?
It really depends on so many factors, that it is impossible to price without seeing the area!
Block paving can range from £60 per square metre upwards depending on what needs clearing, what the sub grade is like, access, type of block used etc etc
Best thing to do is get a number of quotes from local reputable companies and ask them if you can view work that they have done previously, go and knock the door of the home owner as well to see how they view the contractor, the older the job they have done the better, as you can see if anything has gone wrong over time.
The old saying goes as well you get what you pay for, go for the cheapest and expect a cheap job which may not last!
