ChrisR mentions you should you never ptfe the threads of a compresion joint, why is that?
It depends on the type of fitting and the gauge of pipework.When people say "put some PTFE tape on" - how much is some?
A minimum of four, but more if the thread is parallel and loose or the pressure is high.How many layers of PTFE tape do people wrap round a thread to seal it?
It is mostly done by 'feel' - an art, not a science.Or does it not matter?
Actually no - the wet joint is where the olive meets the fitting; the capnut should never get wet.What you are trying to achieve is a water tight joint between the olive and the cap nut
