Hi guys, not posted in a while, but I'd like a bit of advice on a lintel.
I'm a small scale concrete products manufacturer and I've been asked to make a fairly large lintel. I've made plenty of smaller lintels over the last twenty five plus years with no problems and I'd like that record to continue.
The lintel I've been asked to make is 2340mm wide by 325mm high by 230mm deep. I was going to use 6, 20mm rebars welded together to form a cage and would like to know if that is enough. Reading up on various sites, I'm amazed at how small bars are advised to be used.
The mix I've used over the years by volume is 2 parts coarse aggregate, 1 part concreting sand, 1 part cement. I also add fibres to the mix. I use Southern Cement which is 52/N Rated.
I've posted a couple of photos to give people an idea of the load it's got to take.
Thanks in advance.
Thanks in advance.
