Prior to moving into our house, the fireplace that housed a woodburner was bricked up.
Having exposed it, the chimney has a 6" diameter concrete liner which I know was installed about 5 years ago. It looks in good order and if I find a HETAS engineer that is happy to sanction the flue after testing, and I appreciate that not everyone will, what should I be looking to pay if all he has to do is connect the stove, uncap the chimney and stick a chimney cowl on?
I'm trying to work out whether, because it looks building regs compliant, to get a builder who is conversant with the regs in to finish the job at a cheaper rate and then get the cert from building control or will a HETAS engineer be cheaper?
Dan
Dan
