Should the pump be fitted like this? The system engineer left us with the pump running on 3, then the water started bubbling in the overflow /refill tank.
Not sure how include images with my post but this is how the pump looks...looking down into underfloor
//www.diynot.com/network/WillsNana/albums/
I'm sure that the old one had the circular bit facing upwards, as you have to put your hand underneath to get at the three levels (1,2,3), so is this correct?
We've turned the level down to 1 (systems engineer told us what to do) as it's still bubbling on 2.
It's a Grundfos 15-60 130 cat no. 1/44/215 which replaced a
Terrier TC6 TF110 IP44 Class H
Thank you for reading
