We have a very large loft space that I've floored out and have cut 70mm celotex to fit between the rafters, with 50mm breathing space (we also have new breathable felt).
At first I thought the boards would just stay in place, but I guess the drop in temperature is affecting the wooden rafters and the boards have started falling out.
What's the best way to fix them in place? I see Celotex do some tape (http://www.toolstation.com/shop/Con...Insulation+Tape+48mm+x+50m/d210/sd2738/p32233) but I'm not sure if this is any different from the Aluminium tape I got from Screwfix (http://www.screwfix.com/p/no-nonsense-aluminium-foil-tape-silver-72mm-x-45m/50629) which is a bit wider. I also tried putting some screws in which works but probably better to seal any small gaps too.
Does it really matter what tape? Could I just use duct tape instead?
