Good luck, you'll need to use those new seals when rebuilding the boiler. Make sure you compare the sizes of the orings too as some are very similar in size.
Hi, yes I know this is a very old post but I’m hoping someone can help me out, I’m about to do the same thing, but a lot of people say don’t touch the isolation valve on the C/H flow and return as they are prone to leak after, need some advice on what to turn off to do this job, should I turn the mains cold water off and maybe close all radiator valves upstairs (as my boiler is on the ground floor)Well the wife is out tonight so I figured this afternoon would be the best time to have a bash at it. On the whole, I've found taking it apart to be much easier than I'd thought. Most of the time I spent on it was trying to work out if I'd missed something when removing the diverter as it seemed way too stiff. It took a significant amount of force to get off. If I had to take it apart again, I reckon it could easily be done in about half an hour.
I haven't assembled it again yet though - that might take longer. The old diaphragm doesn't actually look to be that bad - there aren't any holes in it anyway. The problem I think is actually just a shed load of limescale. The 'prong' coming out from the diverter to the micro switch was all gunked up and didn't have anything like a smooth motion. Aged rubber in the diaphragm and a gunked up system could easily stop the switch from activating. That's my reckoning anyway.
I'll go about the reassembly tomorrow. I got sidetracked by some phone calls and a conversational neighbour so I couldn't spend as much time working on it as I'd hoped. Plus Wickes is now closed and I'd like to get a tub of silicone grease for the reassembly. I've put some viakal on the limescale and am going to try cleaning that up first too.
Thanks for your very helpful advice, I was only asking for some simple friendly advice.Your lack of knowledge of how your heating system works suggests you are heading for a world of pain, I suggest you get a fixed price repair from WB.
and its the best advice you could have unless you seriously want to pish the mrs off by leaving her with no heat or hot water. There is a reason why all the Pros are saying do not attempt this yourselfThanks for your very helpful advice, I was only asking for some simple friendly advice.
It doesn’t look a difficult job to do maybe a little awkward granted, but I’m a aircraft engineer and have fitted far worse and difficult components, was only asking for someone with experience of doing this work and which is the best way to isolate the water on the C/H and cold water supply will be turned off at the mains, all electrics isolated and covered up plus front control panel removed so no water gets into the circuit board.and its the best advice you could have unless you seriously want to pish the mrs off by leaving her with no heat or hot water. There is a reason why all the Pros are saying do not attempt this yourself
