Hi......
I was hoping to tile onto bonding plaster that i put up when the old plaster and bonding came away in the bathroom when i removed the tiles (2 small areas of 2 X 3 and 2 X 2, feet not inches )....not the whole wall, but i have been advised on this forum that it is not right and i should tile onto a top skim, which is fine with me........ but.......
1) Am i right in thinking that i should pva the bonding plaster (bonding has been on wall for about 2 weeks now and is fully dried) let it dry then pva again and put my 2/3mm multi finish skim on whilst still wet/tacky?
2) As i was hoping to tile straight on to the bonding in the first place i finished it quite smooth, would i need to scratch and rough it up a bit? i was going to get some Thistle bond-it (if thats the right stuff?) but i don't need a 10 ltr tub, for this small area i guess even 1ltr would be more than enough, and it seems such a lot of money for something that i won't use again.
......And finally, i am just a diy-er who gets enjoyment out of doing my own work and i am by no means a plasterer (if it was not going to have tiles put on top i would have got one of you guys in for a professional job ) But something concerns me..........how can a 2/3mm skim be stronger than a 8/10mm bonding, i understand that when done i will have around 12mm thickness but is there a danger that the 2/3mm skim could come off with the weight of the tiles? or does 1 top skim really bond well into bonding plaster? being that it is only in some areas and not the whole wall that i will be plastering, obviously i will butt up to the existing plaster that is good and make smooth....well hopefully smooth
Many thanks in advance for all advice
callard.
callard.
