I'd suggest this as a pinned thread
1. The plumber asks you what you think the problem is. WARNING SIGN. I have several examples from personal experience, so I will give just one. Boiler not working, plumber turns up, has a rummage round and then asks you what you think the problem is. Maybe you did some research on your boiler and found the fan failed often on your boiler type, so you suggest 'maybe its the fan'. The plumber will suggest changing the fan. Your contract is now (in his eyes) for him to change the fan. He changes the fan, boiler still doesn't work. Big arguments ensue. You just asked him to fix the boiler. This is absolutely typical of plumbers no matter what the task.
2. They turn up and don't do a full site survey. Make sure they put in writing what you are paying for in as much detail as necessary. Don't rely on verbal communication. Most plumbers will reject the job if you insist on anything written. So you are stuck. I haven't found any answer to this apart from doing it yourself.
Sounds like you just need to do a bit more research before employing someone, and maybe consider getting a boiler engineer in to fix your boiler rather than a plumber
I've never heard of plumbers rejecting a job on the basis that a client wants things to be written down. Where are you finding these people? Clearly not local recommendations or good-quality trusted trader rating sites
